Re: Design table cannot be opened in Excel
Markku Lehtola Nov 8, 2011 4:57 AM (in response to Ziggi Zag)Try "File-Reload", works for me.
br
Markku
ww.sloworks.fi
Ziggi Zag Nov 8, 2011 5:45 AM (in response to Markku Lehtola)Does not for me - the design table Excel file is actually corrupted - it does not open in Excel at all even while opened with Excel separately of Solidworks.
This is really very unstable - sometimes, very rarely I can create a working design table but it sooner or later is getting corrupted and does not open any more.
Sander Buys Nov 8, 2011 5:29 AM (in response to Ziggi Zag)Are you using Enterprise PDM ? If so, you might have to check in the part prior to creating the design table...
Ziggi Zag Nov 8, 2011 5:45 AM (in response to Sander Buys)>> Are you using Enterprise PDM?
Nope.
Sander Buys Nov 8, 2011 5:56 AM (in response to Ziggi Zag)As you mentioned yourself there are a lot of possible causes for this issue and there are also some reports of bugs resulting in the same error. I once had it resolved by disabling the "send to bluetooth" add-in in excel. Maybe you wanna check this in excel...
Ziggi Zag Nov 8, 2011 6:15 AM (in response to Sander Buys)Sorry - I have no such an add-in in Excel (send to bluetooth) :-(
Scott McFadden Feb 8, 2012 6:40 AM (in response to Ziggi Zag)-
Ziggi Zag Feb 8, 2012 4:09 PM (in response to Scott McFadden)Nope, MS Office is flawless. Obviously, the flaw is in the way SW uses Excel com server.
Bartosz Stefaniak Feb 8, 2012 4:19 PM (in response to Ziggi Zag)i have the same feeling. i've reinstalled SW without any result. W 7 - (64 bit) Office 2007 (32 bit) SW 2011 sp5.0 (64 bit)
Ziggi Zag Feb 8, 2012 5:23 PM (in response to Bartosz Stefaniak)Hehe - same setup like mine :-)
It seem the right solution is switching to Office 2010 x64.
Not confirmed but I heard that from trusted source.
Rgs,
Bartosz Stefaniak Feb 17, 2012 3:27 AM (in response to Ziggi Zag)-
Thomas S. Feb 17, 2012 4:36 AM (in response to Bartosz Stefaniak)Had recently same typ of problem with a big design table (SW2011SP5 XPx86 but no help opening in W7x64). Sent it to SW but they could not restore it in any way...
Peter Andersin Mar 6, 2012 9:08 AM (in response to Bartosz Stefaniak)You need to disable the bluetooth thingie from excels add-ins.
-Peter
Ziggi Zag Mar 6, 2012 1:30 PM (in response to Peter Andersin)>> You need to disable the bluetooth thingie from excels add-ins.
Why the hell there are so many morons believing we all have some "bluetooth thingie" in between Excel add-ins?
Bartosz Stefaniak Feb 8, 2012 5:10 AM (in response to Ziggi Zag)Any ideas if it will also happend in SW 2012 ?
Roel Kersten Mar 1, 2012 5:07 AM (in response to Ziggi Zag)I had the same problem when i first used design tables. (SW2011, Office 2010)
The thing that seems to work for me is creating a seperate excel file, linking to that file and check the box "block model edits to update the design table".
when editing the table, edit it in a seperate window, not within solidworks.
hope this is of any use to you.
Daniel Schulz Apr 17, 2012 11:33 AM (in response to Roel Kersten)I find editing in seperate window actually makes things worse. We use a ton of very large design tables here, and the OPs error sometimes crops up. As other have suggested, re-loads, re-boots, and excel repairs ocasionally help. Unfortunately, sometimes the only fix is to delete the design table, and recreate it. I use auto-create, but it's still usually a lot of work. This issue has been around for several releases.
Kiran P Mar 22, 2013 5:04 AM (in response to Ziggi Zag)I have the same problem.I found another way of making it work.
After closing the message box, right click and click on 'save the design table'.You don't need to save the file.
Now the design table is open inside solidworks and can be edited.Although, you cannot edit it in a new window.
Tom Bostick Mar 22, 2013 9:50 AM (in response to Ziggi Zag)I normally just close Excel and then open the design table again.
Kiran P Apr 11, 2013 5:20 AM (in response to Ziggi Zag)If you have inserted images in your DT, then after a while it cannot be opened in a new window.
I removed the images in my DT and it works fine.
Rod Hayes Aug 27, 2013 12:17 PM (in response to Ziggi Zag)I solved my problem by right clicking on design table, click on "Save Table...", it then seemed to update the table. I then closed without saving and it reopened ok. Hope this works for you.
Junko Fujiwara Mar 6, 2017 10:39 AM (in response to Ziggi Zag)I have the same problem with SW 2017 SP2 running on Windows 7 x64. Microsoft Office Excel 2007
When I tried open the Design Table, I get this error.
Hit "OK" then I get this error.
I've tried "Save Table", but no files was saved.
Microsoft Office Diagnostics found no issues.
I send the file to my software vendors and hope they will recover the data...
But I am feeling that I will have to recreate this part file again...
Craig Schultz Mar 6, 2017 10:48 AM (in response to Junko Fujiwara)-
Junko Fujiwara Mar 6, 2017 11:04 AM (in response to Craig Schultz)Craig,
Thanks for your reply. That might be the cause of the issue.
Boy, I did not know Excel 2007 is End of Life for SW2014.
