Is anyone else having trouble with the properties tab in 2012?
My issue is that when I edit the fields and click apply, if I try to save the file an error will display stating " An unknown error occurred while accessing.." but if i access the properties the traditional way and click ok, the file will now save with out a problem. I've tried using the new 2012 templates but that didn't make a difference.
From the trenches,
Jeff
Hi Guys,
The issue you're seeing is related to an empty date field in the custom properties page. You can avoid the problem by filling in a date value, or as Jeff suggests, by using the old fashioned File-Properties dialog to enter all your values.
This issue has been fixed in SW2012 SP2 which was made public yesterday for EV (early visibility). The final SP2 download should be available in the next few weeks.
Best Regards,
John
