In SW 2011, SP4, I'm trying to set up a cable/wire library and I want to add a column called "Vendor Part No" and add descriptions such as "Alpha # ...". I am able to add the column and revise the column contents, but I can't change the name of the column and make it stick. The interface acts like the name change is saved, but when I reopen the cable library, the column name is still "New-Column-Name1". Can anyone help?
Jon, I am working through some issues right now trying to setup a new cable library so im interested in this. Are you modifying an xml document or are you handling this through the wizard? I would imagine you would need a new XML Source to map these new variables. Something like <Vendor Part No = PDE340-43> under the <cable ID='xxx'>. I would like to hear more on the method you are using to add the headers and hopefully we can figure something out.
