Is there any way to render a section view in photoview 360 SW 2011?
how about when it's an assembly? Would the easiest way be to cut each part separately and rebuild the assembly?
Nope, You can do an assembly level cut.. Go to Insert--Assembly feature--Cut--Extrude. It will leave cut away the section view and leave all of the individual parts alone.
what i do is save the assembly as a part then do the section cuts. Then i would save the bodies as separate part. then import the bodies back into the assembly and mating the origins. The benefit of this is that it leaves the main assembly intact and also allows you to change the colour of the cutaway faces like you see on real cutways. its also handy to put the cutaway parts into an assembly folder so that you can hide/show the cutaway.
