Error when using bolted connection bigger than 50mm
Question asked by David Gimenez on Nov 3, 2011
Latest reply on Nov 21, 2011 by Paul Kellner
Dear all,
I am a Solidworks 2009 user and when I apply a bolted connection bigger than 50mm in simulation, the following message appears: "The bolt diameter appears to be large. Please check to make sure it is correct". The second time I accept this connection the message does not appear but the program does not apply any load and restrain. There is a restriction in the bolt size for this kid of connection? There is any way to increase the bolt connector size?
Also when I apply a bolt connector with “Tight fit” faces, the connector do not apply loads. Is this normal?
Regards,
David
