I have a rather simple weldment with only a few components. Need to show all components but have an item excluded from the cut list. The "Excluded from cut list" option is not working when selected. Item still shows in cut list on drawing.
I have tried both the methods from the help files and have concluded its a minor bug with the software after consulting with Dassault/SolidWorks and our VAR. They have it listed under SPR #573011. Would like to be able to share the files, however they are of a proprietary nature. Thanks for your response.
Did you tried both the methods suggested in the help files for Excluding Folders from Cut Lists
Can you test it on a simple example and verify. Also share the files here to check.
