Hi everyone I am trying to create a top down model of a metal frame which we use in our product. The frame consists of a number of C-Channels, Angles and Flatbars. At the moment I have a good bottom down model but the problem is dealing with all of the design tables for each of the parts and sub-assemblies.
I am just starting out and decided to see if I could model the C-Channel first. The main problem I am having is with figuring out a way to model the bolt holes in the Channel. I first tried using linear sketch pattern, which will actually work but since it records the spacing and the number of holes. However, I find that linear sketch pattern entities are still floating. You don't seem to be able to lock it down unless you add a relation later which wont work if the number of copied entities is being changed in the design table.
What is the perferred method for translating your patterning from an assembly layout sketch to a part?
Thanks for your help
Hi Sean,
This might not answer your question but you said you are modelling the "C" Channels for the Frame. Why aren't you using Weldment to create your frame? You could also use Hole Series to create bold holes within the assembly.
