I want to migrate date that we have on a server to use it with WPDM. First, how do I do it? Second, I tried using the bulk archiving but all my revision numbers fall to 01. I currently use the SW properties for my revisions, all my files name are only the part number. How can the revision number stays the same as what it is right now?
Do you have both primary and secondary revision defined? The custom property Revision you are reading has to use both even if you define both and have "Last Revision type optional" set. In my setup if the file is revision "C", it will not read in from file and would set revision to "A01"
