Maybe I've missed something really basic, but I always assumed that if you were in a sketch, you sketched according to the part coordinate system. So if you are in the Right Plane and create a line from the origin immediately to the right, it should be going in the Z direction. But its not. Until you actually place the line, the system bar at the bottom says that you are going in the X direction. See the attached picture to see what I mean.
Hope that makes sense. Is this always the way it has been?
Keith
if you look at the Z the possitive direction is to the left or pointing to you!!!!!!
put it into an iso view when you draw the line makes it so much easier to understand..
yes it has always been this way..... look at the triad in iso pos Z points to the wall behind you
