I have a part that need a small bend. I'm not sure if I'm using the right approach, but I'm trying to convert the part into a sheetmetal part. I don't think I need to add a bend where I have the two radius (see attach), because those can be cut. Only the area where I have arrow pointing do I need a bend, but when I try to converted it into sheetmetal I get an error. Should I be doing this a different way? Thank you.
It works great if you select the face with two holes under "Sheet metal parameters" and then select the bend sharp edge in "Bend Edges".
Your part has no problems since with this feature does not care about your sheet thicknes, it is assigned within the feature.
