Hi Everyone,
I try to make a task addin for EPDM that displays a data card or a custom control to the user that triggers the task. Then I try to get the data entered into the task job.
To do this, I have translated the sample code provided in EPDM API Help to C#.
In the TaskLaunch process, the sample code states that we can implement a task instance object as follows (VB syntax) :
Private Sub OnTaskLaunch(ByRef poCmd As EdmCmd, ByRef ppoData As System.Array)
'Display a UI just because we can. Typically you would want to display a message box
'Where the user enteres data that is passed to the task add-in via the props pointer.
Dim v11 As IEdmVault11
v11 = poCmd.mpoVault
If v11.MsgBox(poCmd.mlParentWnd, "Hello!" + vbLf + "Are you sure you sure you want to launch the test task?", EdmMBoxType.EdmMbt_YesNo) <> EdmMBoxResult.EdmMbr_Yes Then
poCmd.mbCancel = True
Exit Sub
'Get the property interface used to access the framework
Dim inst As IEdmTaskInstance
inst = poCmd.mpoExtra
inst.SetValEx("MyLaunchVar", "A launch value")
My problem is : in my C# code, I check the inst IEdmTaskInstance object and it is null. That means that I cannot get the entered data to use in the TaskRun process the way the sample intends to do it.
Does someone succeeded in doing a task addin using such data card or custom control ?
Thanks for advice or help.
Yves BLANDIN
CADWARE Systems (VAR for France)
