Is there any body can help to guide to perform flow analysis of blood flushing in the IV catheters?
Example a catheter tube is pre-filled with blood. Need to analyze how much time it will take to flush this blood inside the tube using saline solution. And also find out how much mass of blood is left out in the tube with respect to time.
Make a model of a straight pipe and define two fluids. One fluid will the initial fluid inside the pipe. The second fluid will enter through the inlet lid. Run a transient analysis.
After having done the above, post several cut plots and animations and post your model.
Once you have done at least some work on your own and have shared your results, then ask for guidance.
Rich.
