I've tried for a couple hours now, and I can't seem to figure out how to to get the bumps on the inside surface of the coffee cone. I sort of have it working, but if you look close you'll see that only the original bottom bump is actually on the surface.
From here I'm trying to pattern them around the entire inside, but I'm getting ahead of myself.
I also included another working file that I was using to figure out the coffee cone. Even on this file the bumps are getting all wierd. Is there a way to have them all point inward instead of distorting?
Cheers,
~Rye
Hi Rye ,
I please see the attached step, might these will solve your query on coffee cone part
Regards,
Satish Kumar
