In a -complex enough - part, I am using a surface1 and surface2, twice extruded with sketch1 and 2.
If I want to change sketch2 to sketch3, for using the surface2, how can I do that ?
Of course, I would keep the surface2 name, and all constructions done with surface2, behind the scene.
A joined file to illustrate the problem, but without any sequence behind the scene, using surface2.
How the edit sketch plane, a feature to change the plane of a 2D sketch, can involve a changing of sketch to build my surface2 ?
Btw, sketch2 and 3 are living in the same plane, but the surface2 isn't living in the same 2D "space", since sketch 2 and 3 are totally different.
Basically, what I want to do is just a parametric change, for this surface2.
My BIG present problem is that if I change the content of sketch2, all lines and others will be deleted, and all relations built behind the scene with the surface2 will be in a huge red list.
