Im new to Solid, just started a new job where they are piloting solid works so noone really knows how to work it properly.
Could someone help me how to make a pipe in sheetmetal? i work with big machinery where we have massive sheetmetal components/tubs/pipes.
BR
Johan
Good morning Johan,
Start with a circle and draw a vertical centerline, then draw a diagonal line from the center to the circle, select both lines and mirror. Than trim the circle between the two diagonal lines and add a degree dimension anything from 2degrees to .250 degrees depending on how much gap you want when your finished. Add the sheet metal and give it length and your done.
My computer is acting up this morning so I can't up load a dummy file now, if you need the part drawn out so you can change it to your specs, I am certain one of the guys will step up,
Later,
John
