Hiya,
For some reason, I am suddenly unable to apply any custom materials. The Material Display manager opens as it should, you can browse and select a custom P2M or JPEG as normal, orientate/resize it, but then when you tick OK, it thinks and thinks and thinks for eternity. I've tried lots of different files, at different levels (part/body/face etc) which have all worked fine before.
I initially thought it was a problem linked to a large assembly i've been working on, but its the same problem if a create an entirely new part, having restarted the computer.
I seem to be able to apply default materials fine.
Does anyone have any ideas? I've got deadlines looming and without being able to apply materials i'm stuck!
Tom
In case anyone is interested, i finally managed to fix my problem... its not entirely logically, but turning Open GL on caused it to start behaving normally... and then, bizarrely, when Open GL was turned off again it continued to work.
Not sure the reasons behind this, but the main this is that i'm back up and running.
