I have a problem in converting a sweep into sheet metal and creating a flat pattern also went to the user group and found a possible solution example (solution ID: S-052893), but the flat pattern does not look right.
Could someone help with my part file please.
Thanks in advance
Serge JG
SW cannot recognize that method as a sheet metal part. You will have to use the Lofted Bend method per the example shown in
https://forum.solidworks.com/message/7858#7858
