When I create a report, the legend does not reproduce properly. Below is a screen shot from SolidWorks.
Compare that to the image that was exported into my report.
The range is correct in the second picture; I'd like like to have more values in between. I did not have this problem before 2011. Is there a setting I'm missing?
Same issue here, found a solution which worked for me
Altered the jpg save as options (reset them), which set Image type to RGB full colour, and capture to Screen capture:
Save as
Select jpeg from drop down
Select Options
Select Screen capture
The report then produced images with correctly displayed legends
