Hi All,
Rob from SolidWorks Product Definition here…
Does anyone out there currently define a custom property in their Toolbox parts for standard (or “code” etc)? For example, the Ansi Inch Square Head Bolt is defined in ANSI B18.2.1. Do any of you add this information to your Toolbox parts as a custom property? If so, where do you use these properties down the line (notes, BOM, other table etc)?
I suppose another good question here is - do you ever wish this information came with Toolbox parts?
Rob
I prefer not to have ANSI code.
Then again, I don't ever use square head bolts.
I would probably use BOLT, SQHD,
See attached for other descriptions.
