Where are they listed? There's nothing for 2011 EV 5.0 on the Fixed SPR's page. Are they listed somewhere else?
That's my point. They're not listed. How do you properly evaluate an evaluation version without knowing what has been changed. I've already found a minor bug with the new deletion of Empty Design Tables pop-up message but there's no SPR or change list to reference in my RX (if I even submit one).
Evaluation Versions are more like beta. You test them, report back and then they try to fix those errors in the released SP.
That's what I'm trying to say Jody.
Take e.g. of SW2012 Beta 1. Now until someone test it out, how one can put up a list of "Fixed SPR". So one see the list for Beta 2 and so one. Similar is the case with EV's. Once you test and report, they fix and release the list fore released SP. I'm not sure if VAR has access to that list but it'll not harm if you can check with your VAR.
I believe Beta 1 comes out with a list of SPR's generated prior to Beta 1 that have been fixed for Beta 1. New SPR's generated from Beta 1 (and earlier versions) are then listed as fixed when Beta 2 comes out. What I expect to see is the list of SPR's generated prior to EV 5.0 that are now considered fixed in EV 5.0.
SPR's for the EV versions are not usually listed, wait for few more days to get the SP5 and fixed SPR's list.
