I am struggling with a sketch I don't understand what is wrong. As best as I can tell the contour is open.
What is wrong? I have included the part if someone would like to look at it. The problem sketch is Sketch3 under the boundry surface.
Brent
Brent,
I can't open your part (still back on 2010), so all I can do is guess, based on my own experiences. I suspect that you have more than one open contour. Zoom to the extents and see if there are any extra sketch elements floating around. If that doesn't show anything, check to see if your contour has a gap somewhere. Try select chain from either end and make sure it picks the whole contour.
Jerry Steiger
