High Mach number vs. meshing
Question asked by David Rieke on Sep 23, 2011
Hello to everybody from Germany,
I create a convergence analysis regarding the massflow of a valve. There is a problem with the meshing of the inlet and outlet, these are the lids. A very fine meshing results in the error message "A vortex is crossing the pressure opening" and the solver says that it is necessary to consider a high Mach number. Furthermore, the massflow is very low as if the vortex closes the inlet and there is no fluid flow. But this effect only appears when the number of cells at the inlet boundary condition is relatively high.
I can give you some values:
Boundary conditions: Inlet:      static pressure 141325 Pa
                                   Outlet:   static pressure 140325 Pa
I used a local initial mesh for the meshing of the lids using the inner face of the lids.
Solid/fluid interface:
Refinement level of small solid details: 7
Curvature refinement level: 6
Refining partial cells: 4
Narrow channel refinement: 7
Number of cells for narrow channels: 10
Initial Mesh
Number of cells in x: 22
Number of cells in y: 44
Number of cells in z: 22
Level of refinement: 1
Are there any comparable problems?
Thank you in advance
Best regards
