I'm setting up an SS Heat Generation Rate on a part. If I select multiple separate surfaces for the heat generation rate, is the parameter Q applied to each of those surfaces, or is it divided among all of those surfaces?
Kevin
Kevin
I also had this question. In the training manual it looks like the value you enter is the total for all surfaces selected added up.
