I am working on a tutorial and it says....Create six tall cylinder extrusions with cuts and fillets evenly spaced about the central axis of the part using the Circular Pattern tool.
- Click View, Temporary Axes. WHERE IS VIEW?
This shows all of the system-generated axes in the part. You select one as the central axis of the pattern.
At the top-left of your screen, point where it says Solidworks, a menu will open to the right. Click on View, Temporary Axes. You might have to uncheck Hide All Types before you can check Temporary Axes.
