I have a sketch that I use to mark my parts. I want to export this sketch of my logo as a DXF inorder to have it engraved on a Cnc table. The software on the table takes DXF files.
My problem is that when I export the sketch as a DXF I get a bad looking DXF file. I get lines that are not smooth and overlap other lines. I have various circles and arcs on my logo.
I know a DXF is a line format so I want to know how o can increase the resolution of my exported DXF. I just want to have smoother arcs and circles.
The logo is about 6in x 6in
I am using solidorks 2011.
Good afternoon Los,
Welcome to the Forum
Could you upload your logo? Did you check your dxf file in AutoCad or DraftSight?
Did you try to use it on your machine, it might work ok. If it does then it's your appearance in SW, you can change the line appearance in Tools, Options, Document Properties, Image Quality.
Later,
John
