I did some work yesterday with a part and design tables. I did not finish. Today I have started working on the part.
Yesterday when I would add a sketch or a feature and then edit the design table the design table would have a dialog pop up asking me which of the newly added dimensions/parameters I wanted to add to the table. Today when I add dimensions or features the dialog still pops up but none of the dimensions or feature parameters are in the list. Is there a configuration setting or something that has changed?
My design table is set up in the default was and then I have added some inputs in some of the cells below the default configuration with inputs for the user to enter. There are a few blank cells between the default configuration and the manual inputs. Also, when I manually add a new dimension to the design table the value stays blank until I manually add a value. If I manually add a value THEN the design table links that to the model properly.
Bugs or something else?
Eric,
One thing to get your dimensions to show up in the dialog
box is to rename the dimension. When I do that it shows up.
