I'm having hard time finding the one odd angle in this part. I started having this problem when in assembly I tried to mate it with 3 coincidents and on the last coincident it said that something is not right and that it's 0 degrees. I'm thinking that one of the angles in a very small degree, like .01 and I need to find out which one it is.
Good morning Neeraj,
The first thing you should do and always after today and that is totally define your sketches. You need to open up your first sketch and lock everything down with dimensions and relations. Make your horizontal lines horizontal and vertical, vertical.
That is where you need to start from
Later
John
