1 Reply Latest reply on Sep 30, 2011 6:15 AM by Arthur Jedynak
    Issue with Priniting Drawings to PDF
    Arthur Jedynak
      First of all I should mention that for PDM I am using DBWorks.
      I have wrote piece of software which is allowing me to kind of Pack and Go without opening any files in SolidWorks (every thing is done base on the DBWorks Database). To be able for easy exportation of file. (Look at DBWorks Pack).
      For addition to thta I am attempting to make batch PDF printing from the same software (maybe other things later on). Basicly from the list that is abowe I am attempting to print all drawings. (Look at DBWorks Print)
      And there is the problem starting. I am using Bullzip PDF Printer. Look at the code below (Visual Basic 2010 Express).
                       PartNumber = DataGridView1.SelectedRows.Item(i).Cells.Item(1).FormattedValue.ToString()
                      Folder = DataGridView1.SelectedRows.Item(i).Cells.Item(6).FormattedValue.ToString()
                      revision = DataGridView1.SelectedRows.Item(i).Cells.Item(3).FormattedValue.ToString()
                      sheetFormat = DataGridView1.SelectedRows.Item(i).Cells.Item(5).FormattedValue.ToString()
                      FileName = Folder & PartNumber
                      'Get Part Number without extension
                      For count = 1 To Len(PartNumber)
                          If Strings.GetChar(PartNumber, count) = "." Then
                              number = Strings.Left(PartNumber, count - 1)
                              Exit For
                      Next
                      Dim output = TextBoxPrintFolder.Text & "\" & number & " " & "-" & " " & "Rev." & revision & ".pdf" 'file name
                      'Initiate printer and set settings
                      PrinterSettings.Init()
                      PrinterSettings.SetValue("Output", output)
                      PrinterSettings.SetValue("ShowSettings", "never")
                      PrinterSettings.SetValue("ShowPDF", "no")
                      PrinterSettings.SetValue("ShowProgress", "no")
                      PrinterSettings.SetValue("ShowProgressFinished", "yes")
                      PrinterSettings.SetValue("SuppressErrors", "yes")
                      PrinterSettings.SetValue("ConfirmOverwrite", "yes")
                      PrinterSettings.SetValue("RememberLastFileName", "no")
                      PrinterSettings.SetValue("RememberLastFolderName", "no")
                      PrinterSettings.PrinterName = printer
                      PrinterSettings.WriteSettings(True)
                      'Print
                      Bullzip.PdfWriter.PdfUtil.PrintFile(FileName, printer)
                      'Wait for file before sending another one to be printer
                      While FileIO.FileSystem.FileExists(runonce)
                          Bullzip.PdfWriter.PdfUtil.WaitForFile(FileName, 100)
                      End While
      This is the setup. When I run it with solid works opened it throws an error, also it alwes reads pagesetup from solidWorks file.
      Without Solid Works open there is no error and every thing works fine (apart form turning on SLD sesion and turning of for each print which is taking a bit of time).
      (Look at Error).
      I would like to open for printing in SolidWorks (View mode only) or e-Drawings.
      Can anyone help?
      Best Regards,
      Arthur
        • Re: Issue with Priniting Drawings to PDF
          Arthur Jedynak
          Hi All,
          I found solution by myself. I had to use SolidWorks to open document and set page setup and then print through BullZip printer. Here is some code:
          Exit For
                          Next
                          swApp = GetObject(, "SldWorks.Application")
                          swModel = swApp.OpenDoc2(FileName, 3, True, True, False, 0)
                          pageSetup = swModel.PageSetup
                          If sheetFormat <> "A4 vert." Then
                              pageSetup.Orientation = 2
                          Else
                              pageSetup.Orientation = 1   ' 1=Portrait  '2 = Landscape
                          'Paper size 7 = A4Vertical, 8 = A3, 9 = A2, 10 = A1, 11 = A0
                          If sheetFormat = "A4 vert." Then
                              pageSetup.PrinterPaperSize = 7
                          ElseIf sheetFormat = "A3" Then
                              pageSetup.PrinterPaperSize = 8
                          ElseIf sheetFormat = "A2" Then
                              pageSetup.PrinterPaperSize = 9
                          ElseIf sheetFormat = "A1" Then
                              pageSetup.PrinterPaperSize = 10
                          ElseIf sheetFormat = "A0" Then
          pageSetup.PrinterPaperSize = 11
                          pageSetup.ScaleToFit = True
                          swModelDocExt = swModel.Extension
                          Dim output As String = TextBoxPrintFolder.Text & "\" & number & " " & "-" & " " & "Rev." & revision & ".pdf" 'file name
                          'Print
                          swModelDocExt.PrintOut3(0, 1, False, printer, "", True)
                                         swApp.CloseDoc(FileName)
          Also I have added extension to this small apllication. Export of flat pattern to dxf. I works very good.
