RJRob Jensen15/09/2011
I'm in the need of a macro that will insert text into a drawing.
The macro below works(copyied from the forum), but I need to change the font and make it bold.  I also need the user to pick the insertion point (which i can't figure out) I tried the getinsertionpoint, but for whatever reason it doesn't work.
I have to believe that someone out there has a macro that you pick a spot on a drawing, and it inserts the text.  That's all I need.
Appreciate any help....Thanks...Rob
Dim Part As ModelDoc2
Dim Annotation As Annotation
Dim Note As Note
Dim boolstatus As Boolean
Dim longstatus As Long
Dim myNote As Object
Dim myAnnotation As Object
Dim myTextFormat As Object
Set Part = swApp.ActiveDoc
Set myNote = Part.InsertNote("ITAR") ' Add note annotation and link it to custom property "Test"
If Not myNote Is Nothing Then
   myNote.Angle = 0
   boolstatus = myNote.SetBalloon(0, 0)
   Set myAnnotation = myNote.GetAnnotation()
   If Not myAnnotation Is Nothing Then
      longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
      boolstatus = myAnnotation.SetPosition(0#, 0#, 0#) ' Set the position of note to 0, 0, 0
      boolstatus = myAnnotation.SetTextFormat(0, False, myTextFormat)
Part.ClearSelection2 True
Part.WindowRedraw
