JMJames Moynagh13/09/2011
Hi All,
Have a question to do with springs. I've done a drawing off an assebly which has a spring in it. I've modelled the spring so that when I move certain parts it compresses/depresses. As a result I have 3 configerations in my assembly with the sring in different states off compression, there is no issue with the spring not resolving in any off the configerations. My issue is on the drawing off the assembly. (Attached below). Basically the spring on all three drawings will only show as per the configeration saved in the model, as you can see this causes an issue on the view on the right.
What can be done to fix this or will I have to model another spring in to get this view correct?
