I've been trying to add reference planes to a sheet metal part by rolling back to before the first sheet metal feature (I want to place the SM sketches on new planes)
but when I try to put the sketches on the new planes they are greyed out, like wise if I want to add and use a new sketch to use in the SM base feature,
how can I get these to be includable
SW2010 SP5
This sounds a bit strange to me as well. I just tried a test and it worked fine. Maybe give this a try to see what you get.
I created a test sheet metal part by clicking on the front plane, putting a rectangle sketch there and creating the base flange. Then I Ctrl-dragged the front plane to create a new plane, which placed that plane at the bottom of the tree. Then I drug that plane up to the top right under the origin and before the Sheet-Metal1 feature. Then LMB on the base flange sketch and Edit Sketch Plane and pick the new one. All worked fine.
Notice that I didn't use the rollback bar. When I tried basically the same thing by pulling up the rollback bar & creating the plane, I was then not able to select that plane for the sketch.
I basically always use the first method so that's why I had not seen this one before.
WT
