When we use standard toolbox part in an assembly. While giving pack and go the toolbox parts are also coming is their any way to unselect all at a strech.... not by unselecting them by checking one by one.......
Welcome to SolidWorks forums Praveen.
I'm not sure how to uncheck them all during Pack and Go but you can initially suppress the toolbox parts in the assembly and then do Pack and Go.
You might also find this post helpful for your future reference
You're welcome!
Another similar pack & go trick: If you put linked pdfs and such into the design binder, you can gather all of them easily.
Search for "Type" and put in "solidworks" and "uncheck all" them. Only design binder content remains. Copy them all to a folder to make the product manual! Unfortunately this does not work from windows explorer pack & go, the assembly has to be loaded up.
enjoy,
In pack & go, "Select/Replace..." button, search "In Folder" and put in part of your toolbox path, such as "\toolbox parts" Pick "Uncheck Item(s)", and then "Uncheck All".
