hi all,
seems no matter what search path i specify for pdmworks it will still search all folders subfolders on my drive. it takes way too long to check in a part.
is there anyway to stop this madness?
thanks,
dave
hi all,
thanks,
dave
Perhaps the extensive searching is related to the following:
If Workgroup PDM Options > Command Defaults are arranged to "Include drawings" on Check in, then SolidWorks search path is searched.
The search path includes current folders, folders where referenced documents were last saved, and any folders specified in Tools > Options > System Options >
Unchecking "Search file locations for external references", and minimizing / eliminating folders listed in Referenced Documents should reduce the effort SolidWorks expends in searching.
Best Regards
You may have already tried this, but I don't have many other ideas. In "PDM Vault Admin" you can create an index for the vault items but I suspect that if you have any references within a checked-in file to non-vaulted items, that those locations would be searched also.
