I am trying to control the depth of the thread for different lengths on a revolved feature on a custom fastener. How to add Cosmetic Thread to the design table for different Blind depths? I Tried adding $@Cosmetic_Thread1, and D@Cosmetic_Thread1 $D@Cosmetic_Thread1 and a few other guesses, but I get the error box ...
"Column heading "D1@Cosmetic_Thread1" contains an invalid feature name "Cosmetic_Thread1"."
Maybe I could do it is an added plane and a sketch, but then I would need to control the plane location in the design table ie the "offset distance" of the plane. I don't know how to do that either. Cannot seem to make a sketch work with cosmetic thread.
So the only way maybe to a very tiny feature to the model as the starting location of the cosmetic thread.
Craig,
When you insert the CT, it has a D1 associated with the Dimensin Name, as you ave tried. Your Text appears correct. What Version and Sp are you running?
If you add a 2nd config, then manually change this dimension in the Feature Manager Tree area, you can choose this config, all configs or specified config. Change this only in the THIS CONFIG. Then auto create your DT.
This worked fine for my in SW11 SP3. I will attache the file if possible.
