macro works great 500 times, then crashes
Question asked by Terry Raymond on Sep 7, 2011
Latest reply on Jun 28, 2017 by Deepak Gupta
I have a VB.net macro that finds SW files on my network, opens them one at a time, runs another macro (VBA) on each file, and closes the file.
It runs correctly on ~400-600 files without problem, but then consistently crashes after running for 15-20 minutes.
Most common error:
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred in run macro on multiple files.DLL
**** System.Runtime.InteropServices.COMException (0x80010100): System call failed. (Exception from HRESULT: 0x80010100 (RPC_E_SYS_CALL_FAILED))
   at SolidWorks.Interop.sldworks.ISldWorks.OpenDoc6(String FileName, Int32 Type, Int32 Options, String Configuration, Int32& Errors, Int32& Warnings)
   at run_macro_on_multiple_files.vbproj.SolidWorksMacro.OpenFileAndRunMacro(String filename) in L:\zMacros\run macro on multiple files\SwMacro\SolidWorksMacro.vb:line 153*****
Sometimes it gives this error:
The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
The OpenDoc6 seems to work (errors and warnings = 0), but swDoc goes bad.  Bad pointer?
Solidworks always has the file open when it crashes, so Solidworks does what it is told to do, but doesn't seem to communicate that back to the macro.
I'm able to manually run the second macro without issue.
It doesn't crash on the same file twice, seems like it crashes on whatever file it gets to after 15-20 minutes.
After a crash, I don't need to restart solidworks for it to work again.
I've gone over all the forum posts and couldn't find a solution.  I tried using try-catch; the macro didn't stop but once the error started, the macro encountered the same exception for successive files and couldn't open them.  SPR 524040 looks similar, but is supposidly fixed.
Any ideas?
My code:
' Macro runner  v0.1
' Function:  Runs a macro on all files inside a folder and subfolder.
' Usage:  Set options below and run.
Imports SolidWorks.Interop.sldworks
Imports SolidWorks.Interop.swconst
Imports System
Imports System.Diagnostics
Partial Class SolidWorksMacro
    '*** User Options (Set all these as necessary, back up your data!)***
    Public startpath As String = "S:\QUOTES"  'Root folder Name. Change to folder that has SolidWorks files (end with \)
    Public fileextension1 As String = "sldprt"   'file type to run macro (ie "sldprt")
    Public fileextension2 As String = "sldasm"   'file type to run macro (ie "sldasm")
    Public MacroToRun As String = "L:\zMacros\property copier.swp"        'full path to macro file you want to run on each file
    Public ModuleToRun As String = "propertycopier1"       'module inside the macro you want to run
    Public FileLimit As Integer = 50000    'max number of files to run macro on
    Public FileStart As Integer = 1360        'number of file to start processing
    Public FolderLimit As Integer = 50000  'max number of folders to check
    Public DepthLimit As Integer = 100     'max depth of subfolders to check (0 = don't look in any subfolders)
    '*** end options ***
    Public swApp As SldWorks
    Public swFiletype As Integer
    Public FolderCount As Integer = 0
    Public FileCount As Integer = 0
    Public FolderDepth As Integer = 0
    Public Sub main()
        Debug.Print("  === Start === ")
        'Start looking for files
        FindFilesInSubfolders(startpath)
    'FindFilesInSubfolders
    'looks for all files with the right file extension in a folder
    'runs OpenFileAndRunMacro on each found file
    'looks for subdirectories in the folder, and recursively runs itself
    'will stop when it hits either the Folder limit, File limit, or folder depth limit.
    Sub FindFilesInSubfolders(ByVal path As String)
        Debug.Print("Folder # " & FolderCount & " - " & path & "     depth:" & FolderDepth)
        'get a list of all the files (not folders) in current directory
        Dim files1() As System.IO.FileInfo = My.Computer.FileSystem.GetDirectoryInfo(path).GetFiles("*." & fileextension1)
        Dim files2() As System.IO.FileInfo = My.Computer.FileSystem.GetDirectoryInfo(path).GetFiles("*." & fileextension2)
        Dim AllFiles(0) As System.IO.FileInfo
        Dim skipfile As Boolean = False
        Dim i As Integer = 0
        Array.Resize(AllFiles, files1.Length + files2.Length)
        For Each file As System.IO.FileInfo In files1
            AllFiles(i) = file
            i += 1
        Next
        For Each file As System.IO.FileInfo In files2
            AllFiles(i) = file
            i += 1
        Next
        Debug.Print(" number of files = " & AllFiles.Length)
        'loop through each file, and run the external macro function on each file
        For Each file As System.IO.FileInfo In AllFiles
            Debug.Print("  File # " & FileCount & " - " & file.FullName)
            'count how many files we have opened, exit if we have hit the limit
            If FileCount >= FileLimit + FileStart Then Exit For
            If (file.Exists) Then
                FileCount += 1
                skipfile = False
                'see if file is read only
                If file.Attributes And IO.FileAttributes.ReadOnly Then
                    Debug.Print("      File is read only! removing read only flag.")
                    file.Attributes = file.Attributes - IO.FileAttributes.ReadOnly
                'see if file is hidden
                If file.Attributes And IO.FileAttributes.Hidden Then
                    Debug.Print("      File is hidden, skipping.")
                    skipfile = True
                'see if file is temp sw file  (make this try to delete??? or rename??? if fail, file is open by someone.)
                If Left(file.FullName, 1) = "~" Then
                    Debug.Print("      File is a temporary SW working file, skipping.")
                    skipfile = True
                'don't run we've reached the first start file
                If FileCount <= FileStart Then
                    skipfile = True
                'open file unless skipping
                If (Not skipfile) Then
                    OpenFileAndRunMacro(file.FullName)
        Next
        'get a list of all the subfolders in current directory
        Dim subfolders() As System.IO.DirectoryInfo = My.Computer.FileSystem.GetDirectoryInfo(path).GetDirectories()
        Debug.Print(" number of subfolders = " & subfolders.Length)
        'check how deep we are, exit if we have hit the limit
        If FolderDepth > DepthLimit Then Exit Sub
        'get ready to go one level deeper
        FolderDepth += 1
        'loop through each folder, and recursively run this function on each found folder
        For Each subfolder As System.IO.DirectoryInfo In subfolders
            'count how many folders we have opened, exit if we have hit the limit
            FolderCount += 1
            If FolderCount > FolderLimit Then Exit Sub
            'recursively run the search function again on subfolder
            FindFilesInSubfolders(subfolder.FullName)
        Next
        'we are now back a level
        FolderDepth -= 1
    'OpenFileAndRunMacro
    'Opens a file, runs a macro, saves file, closes file.
    Sub OpenFileAndRunMacro(ByVal filename As String)
        Dim swDoc As ModelDoc2 = Nothing
        Dim bool As Boolean
        Dim errors As Long
        Dim warnings As Long
        'Exit Sub   'enable to just find and count files
        'Open file
        swDoc = swApp.OpenDoc6(filename, GetSWDocType(filename), 0, "", errors, warnings)
        Debug.Print("      Opening file. [" & My.Computer.Clock.LocalTime.ToLongTimeString & "]" & swDoc.GetTitle)
        'Run macro
        bool = swApp.RunMacro2(MacroToRun, ModuleToRun, "main", 0, errors)
        'Close file
        swApp.CloseDoc(swDoc.GetTitle)
    Function GetSWDocType(ByVal filename As String) As Long
        ' Determine type of SolidWorks file based on file extension
        If InStr(LCase(filename), "sldprt") > 0 Then
            GetSWDocType = swDocumentTypes_e.swDocPART
        ElseIf InStr(LCase(filename), "sldasm") > 0 Then
            GetSWDocType = swDocumentTypes_e.swDocASSEMBLY
        ElseIf InStr(LCase(filename), "slddrw") > 0 Then
            GetSWDocType = swDocumentTypes_e.swDocDRAWING
        Else           ' Not a SolidWorks file
            GetSWDocType = swDocumentTypes_e.swDocNONE
    End Function
End Class
