I rarely use Surfacing, and it's kicking my butt. I get lines between these three surface bodies when I knit surfaces. Gaps show up in the PropertyManager but there is no box to check to fix them.
There is probably a very simple fix, but this is only about the 2nd time I have used surfaces. This will need to be thickened 1/16" to the inside. Thanks for any help or advice.
Glenn
I think your primary problem is that you used the sketches to define the loft instead of the edges of the surfaces. I suggest that you instead use boundary surfaces since they are in general superior to lofts. I would also use tangency on the edges of the surfaces and use your guide curves as direction 2. I hope this helps.
Rob Stupplebeen
