9 Replies Latest reply on Sep 7, 2011 4:37 AM by Siva Praneeth
    How to find the points on the beam with maximum and minimum bending stresses using simulation Xpress?
    Siva Praneeth
      I designed a cantilever beam using part.
      and I used fixture to fix the beam as a cantilever beam.
      When I use the simulation xpress to obtain the results, I am getting the simulation results like displacements and von mis stresses.
      What I want to find and verify with my calculated results is " the direction of neutral axis" and also "the points at which maximum and minimum bending stresses occur"".
      Can anyone help me to do this?
      Thank you
      Siva Praneeth V
      3rd year Undergraduate
      Department of Mechanical Engineering
      IIT Kharagpur
