Can anyone tell me how to show file extensions in a Bom table?
Either in the same field as the part number or a seperate field.
Craig
Craig
Craig,
Create a custom property then at the top of the BOM column header
double click and you will see the option under the drop down arrow
to select custom property. Then select the property you created.
Unfortunately looking under the SW system list of properties they do not
include the extension so this looks to be somethying you would have to do manually.
SW System Property List
