resetting of numbering of component instance.
I need to reset this because we check number of instance based on this numbering. Please help.
Lope,
Not sure if this will help you, but you can drag the items in the BOM
to be in any order you want by simply grabbing the end of the row
and dragging it either up or down. You will see a right angle yellow arrow when
you have done this successfully. Keep in mind the only thing that would
prevent you being able to place an item in a certain location in the BOM
would be if the new location interfered with parent child relationships.
Not possible....... Insert a BOM into your sldasm to get the number of components.
Cheers,
Anna
