Not sure if I posted this in the right area... I searched the forums and couln't find anything to fit better.
I just purchased a $1,600 laptop from HP and was TORN between the 2.3GHz Quad Core processor, and the 2.7GHz Dual core...
I read on these forums that a single faster processor is better than multiple slower ones, so I went with the Dual Core 2.7GHz.
My question is will my new laptop run Solidworks quickly without bogging down?
Here's my specs, analize and critisize if you'd like, I hope I made an OK choice. I'm slightly nervous after spending that amount of money.
Thanks for any input!
dv7t
• dark umber
• Genuine Windows 7 Home Premium 64-bit
• 2nd generation Intel(R) Core(TM) i7-2620M Processor (2.7GHz, 4MB L3 Cache) Turbo Boost up to 3.4 GHz
• 2GB Radeon(TM) HD 6770M GDDR5 Graphics [HDMI, VGA]
• 12GB DDR3 System Memory (2 Dimm)
• FREE Upgrade to 640GB 5400RPM Hard Drive with HP ProtectSmart Hard Drive Protection
• No Additional Office Software
• No additional security software
• 30% OFF! 9-Cell Lithium-Ion Battery (over-sized) - Up to 9.5 hours of battery life +++
• 17.3" diagonal Full HD HP Anti-glare LED Display (1920 x 1080)
• SuperMulti 8X DVD+/-R/RW with Double Layer Support
• HP TrueVision HD Webcam with Integrated Digital Microphone + HP SimplePass Fingerprint Reader
• Intel 802.11b/g/n WLAN and Bluetooth(R) with Wireless Display Support
• Standard Keyboard with numeric keypad
• HP Home & Home Office Store in-box envelope
Justin - I wouldn't sweat it too much. That laptop should run just fine, especially if you plan on gaming on the side. I worked for a SolidWorks reseller for about five years, and am back in school myself studying industrial design. The entire ID department uses SolidWorks, and although I'm the only one to actually be running it on a workstation, I see it run every single day on non-certified machines, most of which are Macs. In fact, one of my classmates has the exact same machine that you do, but not spec'd out as nicely, and it runs without any major issues.
That said, if you do run into any trouble, it will most likely be weird graphics behaviour, like a surface randomly disappearing, or sketches/dimensions staying shown even when you've turned them off. Most of this can be solved with a CTRL+Q (forced regen), and none of the artifacts I've seen on screen ever persisted when printed.
Lastly - the processor choice cuts both ways. A higher speed is better for modeling in SolidWorks, while operations like simulation, rendering images, and file opening benefit from multiple cores.
Good luck with your classes!
