Has anyone set up a nonuniform pressure distribution radially from the center of a disc out to the circumference?
In this case I am the reseller ;-) I did create a SR and was told that the only way to do it is by sectioning the disc and applying loads on each face, which is not a very good solution.
However, on Twitter I got an interesting answer from CAPINC's Technical Manager (@mplafleche). He suggested using a Bearing Load. I haven't had time to test this further yet, but will have a go at it. They will be addressing this question in their webcast btw: https://www1.gotomeeting.com/register/699575777
I'm actually wondering about the exact same thing. The nonuniform option requires a coordinate system and we can only define a cartesian one.
