Does anyone have a solution for having the BOM item No., Balloon No. & the Cutlist item No all matching?
Also in the BOM, I have a "Weight" column with a function that multiplies the quantities by the weight of a single item, for some reason I have to do this for each single row. When I try to create this process for the whole column at the header, every row shows the value as the function and not the final numeric result.
Thanks in advance.
Serge JG
Serge,
I'm afraid I don't understand your first question. Since a BOM lists parts and a Cutlist lists bodies within a part I don't see how their balloons can match. If you mean that you want a balloon on a drawing view of a single part to match the item number in a BOM, that can be accomplished by RMBing on the drawing view, going to Properties, and tying the drawing view to a specific BOM. The process is similar for bodies in a Cutlist. If that doesn't help you may need to clarify your question.
I'm afraid I can't help you at all with your second question, hopefully someone else can.
Good luck,
Glenn
