I don't see any option when created a design table for the hole wizard holes. I created a simple hex nut and a threaded hole. But don't see any options when I create a design table for the hole wizard. I don't know if the Wizard's magic powers work with the design table. Are there callouts I can put in the table for hole wizard variables? Or is there a list of variables somewhere for the design table?
Easiest way is to manually create a couple of configs, then use the Auto-Create option to create the DT. Configs and holes can then be easily added.
http://help.solidworks.com/2011/English/solidworks/sldworks/legacyhelp/sldworks/configuration/summary_of_design_table_parameters.htm
http://help.solidworks.com/2011/English/solidworks/sldworks/legacyhelp/sldworks/configuration/hole_sizes_in_configurations.htm
The DT will only change a hole's size, not the hole type.
