I am trying to get the BOM out using VB.NET and the BomListProc3 stored procedure in EPDM. I have the basics of running a stored procedure I think, but I'm lost on where to find the values for the parameters. (I'm using Visual Studio 2010 and SQL Server Management Studio Express 2005)
This is what I have so far:
<code>
'Setup SQL Command
Dim sqlCommand As New SqlCommand("dbol.BomListProc3")
sqlCommand.Parameters.Add(New SqlParameter("@DocID", SqlDbType.Int).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@PrjID", SqlDbType.Int).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@Ver", SqlDbType.Int).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@CfgID", SqlDbType.Int).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@UserID", SqlDbType.Int).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@ShellRoot", SqlDbType.NVarChar).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@oViewID", SqlDbType.UniqueIdentifier).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@bUseLatestVer", SqlDbType.Bit).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@bOneLevel", SqlDbType.Bit).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@bExcludeRootFromResult", SqlDbType.Bit).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@bRespectShowChildrenInResult", SqlDbType.Bit).Value = "")
sqlCommand.Parameters.Add(New SqlParameter("@bStripItemTags", SqlDbType.Bit).Value = "")
Dim sqlConnection As New SqlConnection("Data Source=Astec-sql;Initial Catalog=EPDM_Live_Vault;Persist Security Info=True;User ID=EPDM;Password=EnterpriseQuery...")
sqlCommand.Connection = sqlConnection
sqlCommand.CommandType = CommandType.StoredProcedure
Dim sqlDataAdapter As New SqlDataAdapter(sqlCommand)
sqlDataAdapter.SelectCommand.CommandTimeout = 300
'Fill the dataset
Dim sqlDataSet As New DataSet
sqlDataAdapter.Fill(sqlDataSet)
sqlConnection.Close()
DataGridView_BOM.DataSource = sqlDataSet
</code>
