tried with assembly. but dunno exactly the way to create. plz help me in this.
There has to be 3 parts in this, one for the reducer and 2 branches. Use lofted sheet metal option for the chimney and flat it that way, make cut extrudes on it for the branches before the flatten option. The braches can be done starting with a cylinder and making the appropriate cuts as they go in the chimney.
If you don't need the flat sheet for cutting purposes there's no need to use sheetmetal.
Rohith,
Welcome to the forum.
You might be better served creating it just doing revolved protrustions
and forgeting the sheet metal. Why does it have to be sheet metal?
