I've been creating animations using motion study for a while, and rendering them out (PV360) as avi files. So far, they have all been used in-house and work fine. My question is how best to deal with these files when distributing them to clients on a CD. I realise that this is a bit of an ambiguous question, but my knowledge of video formats and compression types is limited. The reason i ask is that i've found that a 28MB (800x600 24fps 10 sec) AVI video won't play smoothly directly from a CD... obviously fine if copied locally, but i don't want to have to rely on clients to do this.
So... is AVI the best format to use, and what compression level should i try?
Thanks in advance for the help.
Tom
AVI is probably the worst format based on size vs quality. H.264, mp4 compression is the best. You're 28mb avi will probably be about a 1meg file in mp4 format and the quality will be the same.
Download a free program named handbrake to make the conversion for you.
