I have a surface I've been working with. There is a true hole in the surface. When I do an extend surface command it somehow distorts the hole and it no longer has a diameter.
This surface is a "front" and I did the back (which is very similar) without having this issue.
Anyone know what's going on? The surface extend should not distort the hole. Why does it?
Regards,
NG
I find that wiggly surfaces wiggle with seemingly unrelated changes. I just saw one of my surfaces go from 0.0degrees off tangent to 2degrees with a simple 0 offset. If the hole needs to be circular I would add it as far down the tree as possible. I hope this helps.
Rob Stupplebeen
