I can add a olet to a pipe but i can not make the olet to move to a dimension i add. When I add a dimension to place the olet it says it is over defind and won't move. Plus I use angles for olet that are not 0, 90, 180 or 270 I use 45, 35 and 20 degs up.
How do I do this?
What I do is draw a construction line in the route sketch and then exit the sketch and mate the Olet axis to the construction line. With that you can make the angle whatever you want and also dimension the center of the Olet of the end of the pipe.
