I am using SW2011 with SP3.
Is anyone aware of a keyboard shortcut with the Custom Property dialog open that is equivalent to clicking the OK button at the bottom?
I am updating several files in a similar manner. I am adding some text on the Summary tab in the Comments section. The annoyance is that once I click in the comments area, hitting the enter key just gives me a new line. So I have to run my mouse over to my other monitor and click. I know I can hit the tab key 4 times to highlight the OK button then press Enter. I was looking for something a little more direct. This is probably more of a Windows functionality than SW.
Thanks, Daen
Message was edited by: Daen Hendrickson Well silly me! Hitting the tab key 4 times does select the OK button, but hitting the Enter key does NOT activate it...
I'm not sure if there exist any shortcut but did you tried using Property Tab Builder
You can also use a macro to update the properties without opening the Custom Property dialog window.
