JSJohn Stoltzfus17/08/2011
Good morning,
I understand that in 2011 SW you can get the inner & outer cutting lenghts for parts.
I did look in the SW help and the information is sketchy and it says about using the CutList icon.
When I try to add the cut list in the drawingI can choose between WeldCut list or the CutList, however when I select the CutList it shows up as a WeldCut List.  I can insert the cut list in the drawing but all the properties are showing up as welding choices.
Attached is both the part and drawing, and I want to be able to check the outer cutting length of the part.
Thank you for your valued time,
John
